Hi all,
In WBS when I click 'Generate Project Team' I am getting an error and its description is 'object reference not set to an instance of an object'. Does anybody know what this error might refer to? This function used to work, so I am assuming some configuration change caused this problem. In my test environment, this function works. So I compared the two environments. The only noticeable difference is that in test environment resources work hours are as default (cross day) and in my live environment the work hours are set to 8-5.
Thanks
