I discovered after speaking with a Dynamics Support representative that the "closed on" field on the quote entity is not prepopulated ( it is empty by default), instead, the user would have to manually enter the date that the quote was won. Ideally, this kind of field should be populated at the close of a quote. I implore the Dynamics development team to look into this.
Thank You.
