Hello All,
We have created a Data Integration Project, and a Connection set is between Dynamics Finance and Operation and Dynamics 365 Customer Engagement.
From F&O side we have taken Contact V2 table and mapped with Contacts Table from D365 CE. The Project, Connection set and Task works fine, if the Project is Run Manually, however if the project is set for Scheduling, the Scheduled jobs does not gets triggered. Apart from this, if we run Project manually again, it creates a duplicate records in D365 CE. We have enabled Duplicate Detection Rule on D365 CE Contact table, and also created Keys to restrict the creation of Duplicate data, however if Project is still executed Manually, then system creates duplicate records.
Below are the screenshots of Scheduled Job:
Thank you in Advance.
Regards,
Prashant Gamare
