Good afternoon,
I have a request from client to embed a paginated report in a web page on the portal so client can generate report passing a date range and related record ID. the report is power Bi paginated and is generated from a data source external to D365.
the portal user has access to one or more account records, is it just a matter of sending across the unique ID to the report using the liquid tag
should we also send across the date range we already have setup the service in admin area so we know sample report works now we want to pass through some parameters
https://docs.microsoft.com/en-us/powerapps/maker/portals/admin/add-powerbi-report
https://docs.microsoft.com/en-us/powerapps/maker/portals/liquid/portals-entity-tags#powerbi
it seems embedded BI is new to portals has anybody done this with report and not dashboard ? I should not need additional security on BI side as portal application has been added to BI security group???
thanks in advance
Una
