Topic
Replies
Unanswered
Finance | Project Operations, Human Resources, AX, GP, SL
Last replied Posted on by IB-11010704-0 10
Module: Dynamics 365 Supply Chain Management – Asset ManagementScenario:I have a biannual preventive maintenance task that covers 4 separate assets — ...
1
Replies
Suggested Answer
Microsoft Dynamics 365 | Integration, Dataverse, and general topics
Last replied Posted on by MS-29071046-0 0
LCS User license consumption report was working yesterday but today no data available
5
Replies
Suggested Answer
Last replied Posted on by SA-15031413-0 61
Ok so I have a custom field in the extension of SalesTable. I have to update the value of the field across the whole table. So I used this code.public...
7
Replies
Suggested Answer
Last replied Posted on by CU05061123-0 2
We're reviewing an HR implementation where most of the core processes are standard, but payroll rules and compliance requirements change depending on ...
3
Replies
Unanswered
Last replied Posted on by CU14020458-1 0
he problem After our production environment was rebuilt via an environment copy (copied into a new Sandbox, then converted to Production), every ...
1
Replies
Suggested Answer
Last replied Posted on by CU10121822-0 690
Hi team,I have a query. Is both “select first only” and “select” query is return the first record only without where condition?1.CustTable custTable;s...
3
Replies
Unanswered
Supply chain | Supply Chain Management, Commerce
Last replied Posted on by juanrf 15
Hi communityI'm reaching out because, while reviewing the Dynamics 365 Supply Chain Management release notes, we saw that Global Inventory Accounting ...
1
Replies
Unanswered
Small and medium business | Business Central, NAV, RMS
Posted on by RH-05081934-0 0
How do you reverse, void, or cancel an inventory adjustment?
0
Replies
Suggested Answer
Last replied Posted on by CU17070630-1 10
Purpose: The Batch email sending status cleanup process is used to remove old email sending status records that are stored in the SYSOUTGOINGEMAILTABL...
6
Replies
Unanswered
FastTrack for Dynamics 365 forum
Posted on by KS-13051748-0 191
Hi,Trial balance Reporting currency is working fineBut when running the reval on Month end. like July 31st.The FX is the July 31ts When running a...
0
Replies
Helpful resources
Leaderboard > Arizona Power Platform User Group
Featured topics
Product updates
Dynamics 365 release plans
