Post a question
Session Id : QLI83P7mUiC0iF3ucs9S2d
Small and medium business | Business Central, N...
Suggested answer
Navision - how to run general ledger report for more than one nominal code (not in sequence)
Like (1) ShareShare
ReportReport
Posted on 15 Jan 2021 10:51:50 by Microsoft Employee
Hi.
I want to run a nominal activity report for multiple ledger codes (say 7505 and 8100). The only way I know how is to run the report for everything from 7505 to 8100. Is there a way to run the report for only those two codes (other than doing the process separately for each (as I actually have about 30 codes.
I know to run 7505 to 8100 I use ".." so I wondered if there was a symbol that we could use to say 7505 and 8100?
Thanks
Hannah
  • Suggested answer
    Laeticia Cunha Profile Picture
    Laeticia Cunha on 15 Jan 2021 at 12:34:11
    RE: Navision - how to run general ledger report for more than one nominal code (not in sequence)
    Hello,
    If you want to filter the Report, only for the GL Account 7505 and 8100, you should use the symbol: |
    For example: 7505|8100
    In the following link you can find more information about this filter and other filter that you can use in the future if needed:
    Sorting, Searching, and Filtering Lists - Business Central | Microsoft Docs
    Hope this information will help you to move forward.
Under review
Helpful resources
Quick Links
Announcing Our 2025 Season 1 Super Users!
A new season of Super Users has arrived, and we are so grateful for the daily…
Vahid Ghafarpour – Community Spotlight
We are excited to recognize Vahid Ghafarpour as our February 2025 Community…
Tip: Become a User Group leader!
Join the ranks of valued community UG leaders
Leaderboard
#1
André Arnaud de Calavon Profile Picture
André Arnaud de Cal... 292,489 Super User 2025 Season 1
#2
Martin Dráb Profile Picture
Martin Dráb 231,305 Most Valuable Professional
#3
nmaenpaa Profile Picture
nmaenpaa 101,156
Leaderboard
Featured topics
Product updates
Dynamics 365 release plans
Loading started
