Forum boards
Last replied Posted on by .. 1,113
Hi, I'm getting this error: Could not process the lookupRecord value on the Args instance. The table 'Table2' does not exist as a root FormDataSou...
Replies
Last replied Posted on by CU08052056-0 246
Hi experts! I would like to marge multiple projects invoices to one page by using Project Create Sales Invoices below, however I found...
Replies
Last replied Posted on by AM-05091221-0 7
Hi all PR gurus. I had a PR created (Draft), submitted to WF, then it was Approved. The system allowed going from Approved to Draft&nbs...
Replies
Hi, What I understand about entity keys, is that when importing, if i provide an existing value of the entity Key, then it consider it as an update...
Replies
Hi, can we use "register override method" when overriding lookup for reference group? if yes then how?
Replies
Hi, I have a custom table1 with the following fields Id name id1 name1 id2 &nbs...
Replies
Last replied Posted on by D365FO Junior-Dev 46
I created a branch called developer-1 from the main branch in TFVC Azure DevOps I have set up the following mappings for developer-1 branch Metadat...
Replies
Last replied Posted on by faiz7049 1,879
Hi Experts, Customer requirement is to add a field on SalesTable form next to SalesTable_SalesName control name . Users can only enter mobi...
Replies
Hi, I created a table with the following fields: Number Id codeX codeY F...
Replies
Last replied Posted on by CU15120742-0 0
Dear all, Hope you are doing good. My concern is that, Our Finance department is struggling to use web portal Office 365 Dynamic as it's lagg...
Replies
Helpful resources
Leaderboard
André Arnaud de Cal... 291,280 Super User 2024 Season 2
Martin Dráb 230,235 Most Valuable Professional
nmaenpaa 101,156
