Hi All,
I am working on Dropdown in Canvas app. Scenarios is there is 1 Dropdown on select of which Gallery gets refreshed. Same Gallery has same dropdown for each item.
1. In Gallery if Status of that dropdown is Completed or Blocked then dropdown shows as disabled and for other it shows enabled to change status.
2. I want to restrict user that, If dropdown is enabled, user should not able to view Blocked Option as end user should not move item to Blocked.
1st part is completed. For Second part, I am facing issue.
Issue:
If I Do no show blocked in Items of Dropdown it impacts all others. Like if item is already in Blocked state, it shows blank value as I have filter item of dropdown.
Do you have any solution where I can change item list only for specific item in Gallery where user can edit dropdown?
Demo Gallery:
Want to change this Dropdown:
Thanks,
Mayur
