Post a question
Session Id : ZP7BCsOs2Rq490c564gwOt
Supply chain | Supply Chain Management, Commerce
Answered
405 error while transferring shopping cart from CDW portal to D365 F&O Application
Like (1) ShareShare
ReportReport
Posted on 17 Dec 2020 10:43:18 by 25
I am configuring External catalog punch out functionality in Procurement and sourcing. I have configured CDW cXML for this. The issue is, I am getting bellow error while clicking on "Transfer shopping cart" at CDW portal (Ideally it should redirect to F&O screen to allow user to include the shopping cart items in the Purchase requisition).
Any help will be greatly appreciated!
  • sbrozinick Profile Picture
    5 on 21 Jan 2022 at 23:40:29
    RE: 405 error while transferring shopping cart from CDW portal to D365 F&O Application
    Any Update on this error?
  • Rosine  Profile Picture
    5 on 19 Oct 2021 at 17:25:00
    Hi all,
    Any update about this issue? I have the same error
  • Suggested answer
    Dynamics 365 SCM Explorer Profile Picture
    25 on 16 Aug 2021 at 17:26:49
    Thanks Tylor,
    We will raise support ticket.
  • tabarret Profile Picture
    on 11 Aug 2021 at 16:04:54
    Hi Nitin.  I would consider opening a support ticket for this.  There have been some recent fixes around this area that may be relevant.  Someone on our support team should be able to identify if that could help you, or identify another possible solution.
  • Dynamics 365 SCM Explorer Profile Picture
    25 on 11 Aug 2021 at 15:36:26
    Hi Tylor,
    I am again facing the same issue. I was trying to follow the solution steps which you suggested again on Chrome and Edge browser but unable to find those two flags. 1. SameSite by default cookies and 2. Cookies without SameSite must be secure.
    Looks like this is due to browser updates. May the options might have been changed.
    Can you please help me on the same again?
    Regards,
    Nitin Patel
  • Suggested answer
    25 on 08 Jan 2021 at 14:52:03
    Hi Taylor,
    Thanks a lot!
    We have tested the issue with both Chrome and Edge browser and now the issue got resolved.
    For Edge browser, I have followed below steps,
    1) For a user that has this issue in Edge, go to edge://flags/.  Then disable the ‘SameSite by default cookies’ and the ‘Cookies without SameSite must be secure’.
    2) Please disable these two flags.
    3) Close all instances of Chrome.
    4) Launch new and test again.
    Thanks a lot agan!
  • Verified answer
    on 08 Jan 2021 at 00:37:42
    Hello Nitin - are you using Chrome browser?  If so, can you try the following steps?
    1) For a user that has this issue in Chrome, go to chrome://flags.  Then disable the ‘SameSite by default cookies’ and the ‘Cookies without SameSite must be secure’.  These are set to enabled by default starting in v84 of Chrome.
Under review
Helpful resources
Quick Links
Daivat Vartak – Community Spotlight
We are honored to recognize Daivat Vartak as our March 2025 Community…
Announcing Our 2025 Season 1 Super Users!
A new season of Super Users has arrived, and we are so grateful for the daily…
Kudos to the February Top 10 Community Stars!
Thanks for all your good work in the Community!
Leaderboard
#1
André Arnaud de Calavon Profile Picture
André Arnaud de Cal... 292,884 Super User 2025 Season 1
#2
Martin Dráb Profile Picture
Martin Dráb 231,748 Most Valuable Professional
#3
nmaenpaa Profile Picture
nmaenpaa 101,156 Moderator
Leaderboard
Featured topics
Product updates
Dynamics 365 release plans
Loading started
