When I try to export or import entities in D365FO I found out an error like this
System.Exception: Could not load file or assembly 'Microsoft.SqlServer.DTSRuntimeWrap, Version=14.0.0.0, Culture=neutral, PublicKeyToken=89845dcd8080cc91' or one of its dependencies. The system cannot find the file specified.
at Microsoft.Dynamics.AX.Framework.Tools.DMF.ServiceProxy.DmfEntitySharedTypesProxy.DoWork[T](Func`1 work)
at Dynamics.AX.Application.DMFGenerateSSISPackage.`generateFileDataV2Inner(DMFDefinitionGroupExecution _dmfDefinitionGroupExecution, String _defGroupName, DMFFileFormat _fileFormat, DMFDelimiter _rowDelimiter, DMFDelimiter _columnDelimiter, String _codePage, String _locale, NoYes _isFirstRowHeader, NoYes _unicode, String _source, String _textQualifier, DMFXMLStyle _style, String _rootElement, String _filePath, Map _entitySyncVersion, Int32 _previewCount, Boolean _updateOnError) in xppSource://Source/ApplicationFoundation\AxClass_DMFGenerateSSISPackage.xpp:line 1524
Please help with this issue, Thank you
