Hello
Has any one of you has done Dual Write integration between FnO and CE? I am trying to bring Products from FnO to CE however there is not straight way of doing it. Only option we get is to map to Inventory on Hand table in CE which is different to Product Inventory entity. I need FnO to send 10 products of same type with 10 serial numbers so that I can use those products in Field Service using Product Inventory entity to consume products...Only possible solution I can think of is running a flow/Logic App to sync data between Inventory on hand to Product Inventory table.
Any suggestions are appreciated...thanks
