I have created a business process flow that uses two entities.
Volunteer Application (VA)  and Volunteer. (V)
From the VA BPF I'm able to create the V record, but that record ID does not get populated back to the VA (Volunteer Field on the VA entity)
The VA has a referential relationship with V.
In the attached screen shot I have the "Volunteer" field that I need to populate with the new record created in that stage. Right now you can see that I have tried this process twice and both time created 2 new V records, but niether one has populated the "Volunteer" field on my VA entity.
Can this be done?
