Topic
Replies
Suggested Answer
Small and medium business | Business Central, NAV, RMS
Last replied Posted on by RR-07061806-0 832
Good day,   I have an item that was received, relative landed costs were applied and we have the new value of 5,123.96. Items are received in...
6
Replies
Unanswered
Customer experience | Sales, Customer Insights, CRM
Posted on by CU31101219-0 197
    CoPilot usage - ability to see who's using tokens and their user license to inform myself when to move folks between licensing types...
0
Replies
Unanswered
Hello,   I have a question around Center of Excellence toolkit/PowerBI   Why is the below tabs empty the ones with a line through them...
0
Replies
Suggested Answer
Last replied Posted on by AS-20111939-0 40
  I need help with formatting check layouts from Dynamics 365 BC.   We have migrated 22 of the 30 companies from Dynamics GP and I though...
4
Replies
Unanswered
Supply chain | Supply Chain Management, Commerce
Posted on by JB-27021626-0 0
Hi   I am trying to lock down the filter on the InventTrans form so that it cannot be changed. Here is my code:   /// <summary>...
0
Replies
Suggested Answer
Last replied Posted on by KH-27021501-0 0
Based on a respondent's answer to Q1 of the main survey I want to direct to 1 of 4 possible chain surveys.  Is there a way to direct back the re...
1
Replies
Unanswered
Posted on by MA-16101945-0 0 Microsoft Employee
I'm trying to log in to MSX Earnings but I'm getting the following error code (I'm connected to the VPN so I know that's not it):  Can you sha...
0
Replies
Suggested Answer
Last replied Posted on by Honey98 282
I’m facing an issue while running the Assemble-to-Order (ATO) process in Business Central with warehouse handling enabled. 🔹 My Setup: Locatio...
1
Replies
Suggested Answer
Service | Customer Service, Contact Center, Field Service, Guides
Last replied Posted on by CU27021113-1 0
Microsoft keeps asking the particular user to sign it repeatedly. But it doesn't happen all the time. We have already performed the initial troubles...
1
Replies
Unanswered
Hello All,   I heard the other day that Microsoft is starting to recommend not using patches, instead just update the main solution and keep ...
0
Replies
Helpful resources
Leaderboard > Arizona Power Platform User Group
Featured topics
Product updates
Dynamics 365 release plans
