Hi All,
I am trying to install hotfix for a V4 system. I found the hot fix from the below link:
support2.microsoft.com/.../KBHotfix.aspx
I am following the below link on how to install an hotfix:
support.microsoft.com/.../893082
This hotfix are basically kernel files.
After extraction the hotfix, I found 5 folders:
1) ApplicationIntegrationServer
2) Client
3) ComBusinessConnector
4) NETBusinessConnector
5) ObjectServer
Each of this folders contain a "Setup.exe" file which i need to run.
When i run the "Setup.exe" file present in first folder, I get the below error message :
Can anyone help me with this problem?
Regards,
Ajay K S
