Last replied Posted on by MB-08051606-0
Hi, I have a flow that I would like to use to update a list item. The ID of the item is contained within the email subject in this form: /#REF123...
Last replied Posted on by PattiK323 217
Is there a way to change the name of the User-Defined 1 (and/or 2) fields in the Additional Information window in the Employee Card under Payrol...
Last replied Posted on by RH-03050000-0 4
Is there any way to add the Company Logo to these docs? I've uploaded to Company Information section.
Last replied Posted on by Dineshkarlekar 1,363
HI ,everyone,I was trying to info the itemid ,warehouse and physical inventory when invent trans update , can you please suggest me hou ca...
Last replied Posted on by LaserCopr 184
we have items need to populate to website 1) In Dynamics Business Central, can Item have Sub-Sub-Category? 2) can Item have two differ...
Last replied Posted on by CU09050943-0
I have created azure application, and installed that app in D365.I am able to generate token for the D365 instance url. But not for commerce url.I am ...
Last replied Posted on by CU09051530-0
Hi I'm new to the Dynamics environment & started to learn the development, I tried to create a save the contact by providing the required det...
Last replied Posted on by vinoth vk 15
Working on the filter options through ODataV4 endpoints. In the API I have a field name called Description and it has the value. No: "BC001", Description: "Black poly chair" No: "BC002", Description: "Dining Chai...
Last replied Posted on by Himanshu Kamboj 350
Hi All, I have a requirement, like I have 3 applications in dynamics 365 and all three apps having the different-2 custom entities, so my require...
Last replied Posted on by Teevo 302
Hi guys, When writing code in X++ often I want to split my statement into different (separate) line. for example with this code : io.write(/...
Stay up to date on forum activity by subscribing. You can also customize your in-app and email Notification settings across all subscriptions.
Andre Arnaud de Cal... 283,266 Super User
Martin Dráb 222,987 Super User
nmaenpaa 101,140
