Last replied Posted on by xain 480
Hello,i am looking for is there any possibility we can import data using composite data entity without using DMF, i.e. if it can be done via code, wha...
Last replied Posted on by CU01051344-0
Hi, I am creating a simple mobile app for D365 finance and operations. I have just created a simple page to view all the sales order. Initially t...
Last replied Posted on by Rubalingam S 65
Hi, I need to import sandbox environment db backup file (bacpac.) to cloud hosted environment (bak.). While converting it through sql.net tool us...
Last replied Posted on by MA-01050836-0 15
Hello Dynamics Team, We have a situation where we do not want only a particular item to earn any loyalty points in a transaction while other item...
Last replied Posted on by Menna Allah Ahmed 339
I need to create a new custom table like (X table ) and entity with data source of (X table ) then make this entity return only modified records on th...
Last replied Posted on by Gowtham Reddy 24
Hi there, We have an issue with Email templates recently.User created an email template a while ago and chose to use 'New Look' recently. Th...
Last replied Posted on by nbhatti2001 151
Hi, I am using header property "Print on First Page" and it is wokring but leaving blank space on second page. Can I remove this blank space from second page and other pages as well if there. Thanks. Reprot first page Report sec...
Last replied Posted on by Aya Attari 14
Hello Community, I've set up a business rule in Dynamics 365 that assigns a 'Region' field based on the 'Country' field value. This rule wo...
Last replied Posted on by CU03051251-0
Hi, i have a plugin triggering on create post operation asynchronously .Basically i am looping on a list of systemusers, and for each user ...
Last replied Posted on by CU08050724-0 8
i am going to create a service class, which will mark invoice, firstly ,How much amount of invoice is pending with us, we have to find out any or...
Stay up to date on forum activity by subscribing. You can also customize your in-app and email Notification settings across all subscriptions.
Andre Arnaud de Cal... 283,266 Super User
Martin Dráb 222,987 Super User
nmaenpaa 101,140
